turbo questions
Old Dec 18, 2004 | 01:25 AM
99clipsgst's Avatar
Default turbo questions
what would happens if I remove restricter from boost solenoid, is it a good idea and if so how can I do it? Also how do I make the hole in the nipple on the stock boost controller slightly bigger.
Old Dec 19, 2004 | 03:57 AM
midnght's Avatar
Default RE: turbo questions
it is done with a simple woodscrew. You can not make the hole "bigger". Removing the plastic inner sleave will do it for you.
Get a boost gauge and a simple MBC. Set it appropriately and you will be good. Do not do the MBC without a "real" boost gauge.
Old Feb 14, 2005 | 11:01 AM
t3t4turbo's Avatar
I second that! Get a boost gauge first!!! Can you say CAAAAAAAAAAAAAABOOOOOOOOOOOOOOOOMMMMMMMMMM!!!!!
You dont want detination, its bad.
Old Feb 17, 2005 | 05:04 AM
DSMTalonAWD51's Avatar
yes follow the words of the wise. thall shalt not increase boost without a boost guage and a fuelpump
but removing that restrictor in the selenoid will give you an extra couple lbs of boost until u get the boost controller
Old Apr 6, 2005 | 12:03 AM
1998blackgst 240's Avatar
Wheres the turbo selenoid?
Old Apr 6, 2005 | 03:58 PM
http://www.jumptronix.com/2g_go_faster/index.htm -> FAQ/How To -> Boost Control Selenoid
Old Apr 6, 2005 | 06:37 PM
thats awesome, thanks alot
Old Apr 7, 2005 | 09:44 PM
vertstanggt's Avatar
def go with a boost controller. I'm getting a couple gagues and a MBC this summer once I get all moved into my house.
Old Apr 8, 2005 | 01:46 AM
Sanguinius's Avatar
Wish I could afford a couple of gauges and a MBC BUT first I need to get mine rollin on it's own power LOL. That's gonna require a head/valve job and a wee bit o body work LOLAnyone wanna help here?? :P
antomx
Sep 7, 2006 05:29 PM
2insane
Aug 20, 2006 07:33 PM
Xavier
Jul 12, 2006 04:08 PM
willdue
Mar 19, 2006 03:35 AM
Watts9614
Sep 15, 2004 02:04 PM
