Bad Ecm??
Old Jul 3, 2008 | 11:48 PM
Scubba.steve's Avatar
Default RE: Bad Ecm??
Yes, low input and also high input
Old Jul 4, 2008 | 07:20 AM
dsm1990gsx's Avatar
Oh well that makes it more interesting lol.
Old Jul 4, 2008 | 07:26 AM
dsm1990gsx's Avatar
Pm me your email address and I'll email you the pinpoint tests for both iat codes.
Old Jul 6, 2008 | 01:21 PM
Nubiebubie_GSX's Avatar
I think the part about not being able to swap ECU with the same generation is a load of crap. People swap out there ecu for the 95 version often enough so that proves it. Also i have a 98 and i am using a 95 ecu. Not claiming this for all cars but for these cars you shouldn't have a problem. I had a bad TPS and it woudl cause surges and cause the car to buck back and forth really hard when the car was in 1st gear and ur moving slowly. Check the readings with an ohm meter and notice it fluctuates alot. Drove with it disconnected and i had no problem so i replaced it and problem with the surges gone. Easy test u can try.
Old Jul 6, 2008 | 01:33 PM
feonixwolf's Avatar
could not tell if you are turbo or not,if so maybe try a boost leak test.i was having the same problems,found the TB seals leaking.
Old Jul 6, 2008 | 01:45 PM
dsm1990gsx's Avatar
ORIGINAL: feonixwolf
He's a non turbo
Old Jul 6, 2008 | 01:56 PM
feonixwolf's Avatar
could still do a TB and intake leak test.see if the seals are sucking extra air.
Old Jul 7, 2008 | 01:51 PM
TPS is brand new
Old Jul 18, 2008 | 01:47 AM
Well i decided to take out my ecm today just to have a look...... There stamped on the side was a remanufactured date. My ecm had been rebuilt in 2003. So i put the ecm back in started to trace my wires for any broke or loose connections...... There on the thermostate housing is a ground for the ecm...... It had wiggled itself loose and fallen off. I reatached the ecm ground to the frame and so far everything is back to normal
Old Jul 18, 2008 | 06:31 PM
dsm1990gsx's Avatar
Nice job.
nawgee
Oct 20, 2008 06:24 AM
agallardo
Oct 1, 2006 02:07 AM
90Mirage
May 8, 2005 04:13 AM
Xit40
Jan 21, 2005 06:04 PM
cooley
Apr 2, 2004 03:03 PM
