Bad TCU-Need solenoid wiring & shift pattern to make a shift box
Old Jul 12, 2015 | 07:22 PM
Eclipse440's Avatar
Default Bad TCU-Need solenoid wiring & shift pattern to make a shift box
My tranny is dropping into failsafe mode after several minutes so I'm going with a bad TCU as the culprit. Trying to find a reputable shop to work on these things is another matter entirely. I've got a few I'm looking in to.
Meantime...I can get it going by making a manual 2 switch shift box...BUT I need the shift pattern.
I found wiring and shift patterns online for the 1g but I don't think its the same for a 2g. According to the 1g pattern I found online....both solenoids off should be 1st gear and I just drove my 2g around the block with no TCU computer in 2nd gear. No computer should = no power to either solenoid...unless the EATX relay is supplying power to solenoid A when the TCU is removed as part of failsafe mode...? Hmmm....anyone know about that?
Either way I could use the wiring and A B solenoid pattern for the 2g so I know how to shift the thing.
Also anyone know if its safe to use a relay to engage the lockup converter at the same time as 3rd and leave it on for 4th as well? I don't see why it wouldn't be.
Thanks - Dave
Old Jul 14, 2015 | 11:08 PM
mxmikie's Avatar
nena604
Sep 25, 2013 07:59 PM
Riotralph
Jan 5, 2011 07:46 AM
nena604
Mar 29, 2006 06:34 PM
galantgtz01
Mar 25, 2006 05:49 PM
nena604
Feb 7, 2005 11:33 PM
