Battery recharge problem on gst
Old Jul 15, 2006 | 01:53 AM
gst4me's Avatar
Default Battery recharge problem on gst
I have a 98 gst that was running great till my battery light came on. The alternator burnt up so I replaced it. Now the alternator is perfect but the battery light is coming on because the alternators not putting out 12v . I heard that the computers could be causing this..... any input would be appreciated........ thannks
Old Jul 15, 2006 | 09:06 AM
Default RE: Battery recharge problem on gst
Your battery is ****ed
Old Jul 15, 2006 | 09:35 AM
magnet's Avatar
ORIGINAL: Sebba
ditto
Old Jul 15, 2006 | 12:40 PM
gst4me's Avatar
So you guys think that is all thats wrong?
Old Jul 15, 2006 | 01:51 PM
Yep. Ok if you have a decent battery you should have a little peep hole that you can look through to check the condition of it. If its black or white you need to repalce it... green is good.
Old Jul 15, 2006 | 03:45 PM
gst4me's Avatar
I tested the batt. with a voltage meter and it registered right at 12v but my alternator jumps up and down on how much voltage its pushing out.... it will be at like 11.4 then drop to 5 then back to 8v
Old Jul 15, 2006 | 04:00 PM
ok then either you have a short some place. or your alt is bad again or you have a loose wire.
redturboeclipse
Jul 6, 2014 02:52 AM
chmeftwc
Sep 18, 2010 03:23 AM
jeranic
Aug 23, 2009 09:30 AM
lovinmrv
Aug 15, 2007 10:50 AM
