Blow OFF VALVE...
Old Feb 5, 2006 | 05:38 PM
WIECLIPSEGUY's Avatar
Default Blow OFF VALVE...
I am a new owner of a 97' GSX Eclipse and was wondering if I can put a blowoff valve on a automatic car? and the egine is stock Turbo and was wondering if you can point me in a direction that would give me some information on Mods with the Blowoff Valve and increasing the size of boost of turbo... Thanks Everyone..
Old Feb 5, 2006 | 06:39 PM
Default RE: Blow OFF VALVE...
Oh Geez... Your car already has a BOV stock(plastic junk too) yes you can upgrade and alot of 2G eclipse\Talon owners buy the crushed 1G BOV... to run more boost buy a boost gauge and a Manual boost controller your stock PSI is 10-12 you can safley run 15-16 on that turbo and fuel set up. for higher PSI than that youll need fuel upgrades and a turbo upgrade.
You should get a full Turbo back exhaust 3inch diameter as well if you plan on running more boost
Old Feb 5, 2006 | 06:42 PM
badass91hatch's Avatar
of course you can put a blow off valve on an auto.i suggest a greddy type-s.and manual boost controllers a readily avaliable and you can set your psi with it.it is not recommended to set the stock turbo past 16 psi.also a boost gauge is required in conjunction with a boost controller.
Old Feb 5, 2006 | 07:16 PM
Thanks Guys... can you point me in a direction with a link to buy these type of products... Never been in the import world before... All new to me.. Thanks for the help guys!!!
One thing I can say is that everyone is so kind here... Unlike some others that are expecting you to know everything... Thanks Again to all!!!
Old Feb 5, 2006 | 10:07 PM
ORIGINAL: WIECLIPSEGUY
Ebay can be your best friend on some of these things as can google. The Greddy Type S as well as the 1G crushed BOV or very cheap and both are great upgrades from your stock BOV
Old Feb 5, 2006 | 10:49 PM
I have the laptop in my lap and watching the Superbowl too. Sorry. Question, do I have to change anything or can I just change the BOV by itself. I would like to do these mods little at a time. I got little over my head with my Camaro and next thing I know I am $12K into the project...
Well if you buy an aftermarket BOV make sure you get a recirculation kit for it so your car can run properly
Old Feb 6, 2006 | 09:59 AM
get435's Avatar
ya you can change just the bov for now and slowly mod wont hurt anything if anything your will see a little bit better running car hear the stock beov is notorious for slight boost leek.
Old Feb 6, 2006 | 01:40 PM
Thanks for putting my mind at ease with changing the BOV. It is good to know that the stock BOV's are known for leaking. I hope the car runs better with a new one then.... What is the best place you guys shop to get these type of products.... I think I am suposed to be looking at "TYPE S" is that correct?
Old Feb 6, 2006 | 07:19 PM
brandoN^gsT's Avatar
http://cgi.ebay.com/ebaymotors/GREDD...QQcmdZViewItem
Theren you go. It's not actually made by GReddy. It's the companies version. So, it's GReddy Type-S style BOV.
If you go to http://www.motors.ebay.com and search for Eclipse BOV, you will find more. They have some pretty nifty prices there
Good luck!
-brandoN^-
Old Feb 6, 2006 | 07:37 PM
Brandon, Thanks for pointing me in a good direction. Do you know anyone who is running it. How does it sound and did it improve the cars performance? Thanks Derek
