Blow OFF VALVE...
Old Feb 8, 2006 | 09:13 PM
  #41
93eclipsegsx's Avatar
Default RE: Blow OFF VALVE...
he asked meif i got it ported with a bigger wastegate flapper.
and im saying no.
Old Feb 8, 2006 | 09:33 PM
  #42
anko_kun's Avatar
ok i see now sorry brain fart
Old Feb 9, 2006 | 09:50 AM
  #43
get435's Avatar
you may want to look into getting this done with teh evoIII that you bought has a bad issue with boost creep.
Old Feb 9, 2006 | 08:41 PM
  #44
what do you mean??
not quite getting the gist
Old Feb 10, 2006 | 10:13 AM
  #45
The adjuster on the greddy bov doen't really do much for performance. All it does is change how much air it releases and how long it realeses it for. So it s really only for sound.
Old Feb 10, 2006 | 11:21 AM
  #46
WIECLIPSEGUY's Avatar
Any Pointers on how to adjust to sound. "Adjust on how is suposed to be."
Old Feb 12, 2006 | 10:02 AM
  #47
get435's Avatar
ORIGINAL: 93eclipsegsx
what do you mean??
the evo III turbo wastgate flapper is a little too small so when you boost the wastegate kicks in when desired boost is reached well if the flaper for the wategate it too small your turbo will continue to slowly go up on boost gauge you will set for 14 psi and it will hit it than slowly go 14, 15, 16, 17,.... the way to fix the issue is to port the turbo=better flow and get a gigger flapper
Old Feb 12, 2006 | 10:11 AM
  #48
ORIGINAL: TheEngineer
well it is basically a tensioning adjustment, it makes the spring harder or softer if it is harder it stays open less time
Old Feb 12, 2006 | 05:00 PM
  #49
DSMTalonAWD51's Avatar
it does is yuou plan on running high boost. low boost you leave it at a soft setting so it will relieve all the pressure. once you run high boost you make it stiffer so it wont leak.
most people dont touch the adjustment on their bov but it can be of importance
Old Feb 12, 2006 | 09:21 PM
  #50
ORIGINAL: get435
what do you mean??
yeah, when im driving and i punch it, it does exactly what your saying. so the only way to fix it is to get a bigger flapper and port the turbo
