Bolt On replacement turbo
Old Sep 13, 2006 | 03:46 AM
TX97GST's Avatar
Default Bolt On replacement turbo
I have a EVO III Big 16g from FP. I want more power. Without having to get a new exhaust mani, and O2 housing, what is a bigger replacement for the 16g. Will something like a 20g-5h bolt up?
Old Sep 13, 2006 | 10:09 AM
Default RE: Bolt On replacement turbo
why dont you just try and get more out of the 16g. That turbo is capable of alot with a built up motor and a good tune.
Old Sep 13, 2006 | 06:09 PM
DSMTalonAWD51's Avatar
have you dynoed or tracked the car? in my experience most people dont know how to tune, think they need a turbo, then get dissapointed when they spend another $1000 on a bigger turbo and dont get any faster. i was able to run mid 11's on a 16g and never felt the need to upgrade, i liked the fact that I could hang with 911's and my turbo still spooled quick. Monster turbos may make a lot of power, but on a lil 2 liter motor you dont even move until the damn thing kicks in.
Old Sep 14, 2006 | 03:13 AM
badass91hatch's Avatar
dam...what did you have to go with the 16g??
Old Sep 14, 2006 | 09:25 AM
like he said, its all about tuning and building the block enough to hold the power your trying to get.
Old Sep 14, 2006 | 01:46 PM
it wasnt even that crazy of a setup, full 3" exhaust, big 16g, filter, bov, upper ic pipe, mbc, safc, walbro 190 and denso 660's.
I can easily say tuning is the most important aspect of getting fast. I spent tons of time reading up on it and more time changing settings around until it felt right. Im sure I could have done better, I didnt even use a wideband, just a pocket logger and went off timing curve and butt dyno. The one other important piece of advice I have though is only buy denso or rc injectors, stay away from fic/pte/any other cheaper brand or you will have a hell of a time tuning them (with safc/maft, they are fine with dmslink/greddy emanage)
Old Sep 14, 2006 | 01:48 PM
building the block isnt even important for a 16g turbo. blocks can handle more power than a 16g can give. the only thing that may happen is you may blow a head gasket if its old. Then you just get some arp bolts and a new gasket and you are set. My motor was a 6 bolt bottom end with 2g head/2g pistons and all arp hardware. I could have easily done the same thing with a 7 bolt motor though.
Bcr5165
1st Generation
Apr 26, 2011 11:26 PM
red93gs
Nov 30, 2006 02:56 AM
bud660r
Aug 31, 2006 07:41 PM
petro4411
Dec 5, 2005 01:42 PM
antomx
Sep 29, 2004 02:32 PM
