Boost leak?
Old Feb 25, 2007 | 09:13 PM
keithscianna's Avatar
Default RE: Boost leak?
I will to the leak test again, i was using a hand pump maybe i will go to the gas station anddo it.Also i am running extreamly RICH.... The plugs i put in today and drove 10 miles on are black and coverd in SOOT. what does this mean?
thanks,
keith[/align]
Old Feb 25, 2007 | 10:04 PM
the black is just from running rich. Its carbon deposits.
Old Feb 26, 2007 | 01:06 AM
What does that mean?. the plugs were bran spanken new..
Old Feb 26, 2007 | 01:42 AM
I Drive Naked's Avatar
Running rich... check your O2 sensors lately?
Old Feb 26, 2007 | 03:05 AM
silvercoupe97's Avatar
Well, your "hello" post shows that you have an AEM fuel rail with ?sized injectors, 16g, and no fuel managment. I would think that, that may cause some of that richness.
Do you have an AFPR or upgraded fuel pump?
Old Feb 26, 2007 | 03:40 AM
I have the FPR but i am not sure about the pump. I would guess the previous own would have done that but you never know, There is a fuel pressure guage in the engine bay. What would be the correct fuel pressure for my setup? I can pull the pump and look to see what it is if that would help. Also i am looking into a safc or dsm link but they are pretty expencive. If i were to "barrow" one and tune the A/F mixture then remove it would it keep the settings or just reset back to the previous?
thanks,
keith
Old Feb 26, 2007 | 03:56 AM
Yeah, the settings are saved in the SAFC. Once you remove it, the settings are gone. The SAFC is a piggy back system, so all the settings are in it. DSMLink is a little different because there's a chip in the ECU that gets programmed by you. You can remove the laptop/pda, but the chip remains along with the settings.
What does your fuel gauge show? Also, what is the gauge connected to, the AFPR? BTW, AFPR = Adjustable Fuel Pressure Regulator. FPR = Fuel Pressure Regulator, means that it's non adjustable.
Hopefully, the previous owner didn't remove necessary items, like larger injectors or an aftermarket fuel pump, lol.
Old Feb 26, 2007 | 04:07 AM
Ok there it is in green, I will give you some readings tomarrow when i get home, I'm at work right now (graveyard) So i will have them for you tomarrow. thanks,
keith
Old Feb 26, 2007 | 04:08 AM
Do you have something that looks like this..
[IMG]local://upfiles/10268/7A29D762FB0140D896121B9F469AF6CC.jpg[/IMG]
...installed like this..
[IMG]local://upfiles/10268/D41A98F5E51A4DE7A41BFDCB98DEFCC7.jpg[/IMG]
or similar?
Old Feb 26, 2007 | 04:12 AM
ORIGINAL: keithscianna
keith
It looks like the gauge is connected to the fuel filter.
