boost leak.
Old Sep 14, 2008 | 09:41 PM
needsagst98's Avatar
Default boost leak.
i have a 98 gst. i did a boost leak test and i heard a hissing sound up near the throttle body. what things could be leaking up there besides throttle body?. or would it jsut be that. i know its not the ic elbow pipe becasue that has a brand new gasket. im thinking between TB and Intake mani.
Old Sep 15, 2008 | 03:50 AM
silvercoupe97's Avatar
Default RE: boost leak.
Yup, TB, vacuum lines, BISS, TPS (plus its gasket), cable pulley (plus its gasket), MDS...um sensor, fuel injectors...yup, FIAV, IAC, fuel injectors, intake mani to head (doubt it though), that's pretty much it.
Old Sep 15, 2008 | 06:39 AM
i would also check the TB shaft seal. These are known to leak and cause boost issues. Check to if the air is comming from the area near the throttle position sensor. If so then check out this write-up
https://mitsubishiforum.com/m_104128/tm.htm
also note the last post tells you where you can purchase the seals from
Old Sep 15, 2008 | 08:06 PM
engineer i think thats exactly where it is leaking from. when i heard the leak i pushed on the throttle cable on the side of the tb to like shut if more and the hissing sound went down a good bit, and when i let off it went up again. sound like Tb shaft seal?
Old Sep 15, 2008 | 10:23 PM
replace them anyway. they are cheap and easy to do.
Old Sep 16, 2008 | 06:33 AM
yup, id just replace them and see if it solves the problem
TheRock0720
Nov 12, 2010 12:30 PM
ryant25bb
Oct 16, 2006 09:35 AM
ryant25bb
Oct 10, 2006 11:36 PM
thehintons06
Sep 28, 2006 05:10 PM
mr casual
Dec 26, 2005 07:00 PM
