BOV won't go off when i rev engine
Old Oct 2, 2008 | 11:39 PM
Pribs's Avatar
Default BOV won't go off when i rev engine
I have a greddy rs bov and when I rev the engine it won't go off. I tried adjusting it hard or soft but still won't go off. When I shift everything is good and it goes off but not when I am in neutral and rev the engine. It's recirculated and I think thats why. I just want to be sure. Any help is appreciated
I am running...
Small 16g @ 10 psi
SMIC w/ hard lower and upper piping
Old Oct 3, 2008 | 12:08 AM
silvercoupe97's Avatar
Default RE: BOV won't go off when i rev engine
With the pressure on the valve from both ends, it won't open like a vented BOV. This is normal.
Old Oct 3, 2008 | 05:25 PM
You need to have a load on the engine to build boost. As long as it sounds normal when you shift, then it is working.
Also, it may be opening, you just can't hear it because it is recirculated.
Old Oct 3, 2008 | 05:43 PM
dsm1990gsx's Avatar
Yeah you wont really hear it when you rev it up at idle b/c the engine needs a load to build boost.
th3thc
Aug 18, 2010 11:21 PM
snomanz600
Sep 3, 2006 04:32 PM
Shadowplane676
Jan 4, 2006 02:21 AM
badass91hatch
May 6, 2005 02:32 PM
alvar
Mar 24, 2004 11:55 AM
