base 3L rev capabilities?
Old Oct 30, 2005 | 07:55 PM
Shadowplane676's Avatar
Default base 3L rev capabilities?
i have a distributed n/a base 3L engine, its current redline is 6000. i was wondering what the engine is capable on stock components. can it go up to 7000, or 7500? it is the over-economized 3L used in the crystlers, rated at 145 hp stock
Old Dec 15, 2005 | 09:35 PM
jakster's Avatar
Default RE: base 3L rev capabilities?
So you are saying you have a base model with a SOHC engine is that right pushing the motor at that extream in stock mode is a tough call where it will blow up is a better question. The year matters also because of the crank and the four bolt V/S two bolt mains. Need more information.
Old Jan 4, 2006 | 02:21 AM
it is a 1992, and i was wondering if you were to put in some better springs and modify the rev limiter, where you could go with that, an extra 500-1500 rpms? that sort of thing. i think my block is a 2 bold no teh 4 bolt block
92gsx
1st Generation
Jan 15, 2007 08:51 AM
snomanz600
Sep 3, 2006 04:32 PM
gstTurbo2011
Sep 3, 2006 06:11 AM
5Tizzle
May 27, 2006 08:34 PM
alvar
Mar 24, 2004 11:55 AM
