Burning motor oil fast
Old Apr 14, 2010 | 03:43 PM
JOSHDIZLE's Avatar
Default Burning motor oil fast
i have a 1999 Eclipse GS Spyder with 80,000 miles on it. i changed my oil about a month ago and i heard clicking coming from my engine and i knew it was because of the oil. When i checked the dip stick i was 3 quarts low. i have only driven 1,800 miles since the oil change. There is no smoke or any leaks when i drive and park. any ideas?
Old Apr 15, 2010 | 06:40 AM
lifter tick...no big deal
Old Apr 15, 2010 | 03:22 PM
JOSHDIZLE's Avatar
The tick did go away after I added more oil I'm more concerned as to why I was three quarts low after only 1,800 miles.
Old Apr 15, 2010 | 04:07 PM
dsm1990gsx's Avatar
Did you do the oil change or did you have a shop do it?
Old Apr 16, 2010 | 03:27 PM
JOSHDIZLE's Avatar
I had a Shop do it.
Old Apr 16, 2010 | 04:29 PM
sounds like they either didnt put enough in or you have a small unnoticable leak. One thing i had happen to me when a shop did my oil change was they didnt put the washer back on the drain plug bolt and that caused a small leak. Luckily for me i caught it the same day and redid the oil change.
Old Apr 16, 2010 | 07:27 PM
dsm1990gsx's Avatar
If you have no leaks and no smoke, sounds like the shop didnt put enough oil in it.
Next time do the oil change your self, fill it, mark the dip stick and drive it for 1k miles. Recheck and see if the oil dropped from the mark.
Old Apr 19, 2010 | 03:04 PM
JOSHDIZLE's Avatar
ok thanks I'll try both of those suggestions.
cdvyas20
Feb 19, 2013 06:24 PM
rapperbasher
May 7, 2007 02:53 PM
monterodude
Dec 18, 2006 02:33 AM
WhiteTrash93
1st Generation
11
May 20, 2006 12:44 PM
shivan15
Oct 19, 2005 03:27 PM
