six bolt swap going strong but!!!!!
Old Apr 20, 2010 | 08:30 PM
2slow's Avatar
Default six bolt swap going strong but!!!!!
Okay noobish question here do i have to remove the trans entirely to get the old motor out or is there a way i can get it out with out dropping both the trans and the engine? i have everything i need to do the swap i just need to know this one minor detail.look things were going well so i have my old crank walked engne held up on the cherry pick and my six bolt on a engine stand if i have to i can mate them on the ground but i figured that i could get around this i suppose if i were to release the front and rear trans mounts. Would that allow enough movement of the transmission to drop just the motor out of the bottom, or should i go on and drop the trans as well your the pro engineer let me know what you know.
Old Apr 20, 2010 | 11:48 PM
Honestly it would be easier with the transmission attached. You can pull them separately and slide it out, but you'll save yourself some time removing them together.
Old Apr 21, 2010 | 12:44 PM
dsm1990gsx's Avatar
Its easier to pull them both out together, just remove the hood so you have plenty of space.
Old Apr 21, 2010 | 11:49 PM
2slow's Avatar
okay let me get this straight i can go through the top but i need to remove them together okay tomorrow will be day 2 lets see where i can get
Old Apr 22, 2010 | 07:18 AM
we are not saying you NEED to remove them together, you could drop the tranny and then lift the engine, but what we are saying is it is way easier to just remove both at the same time. Will save you alot of time and effort
Old Apr 22, 2010 | 01:27 PM
2slow's Avatar
okay i got the trans out this morning and the motor came out with ease. I found out the hard way well i have the six bolt and the seven bolt head combined turbo mounted, and now i am about to start the easy part putting it all back together but how can i tell if i have the cam angle sensor in time its about ready to go but i need to know this one little detail thx
2slow
Mar 16, 2010 11:05 PM
pawleywog66
Jul 1, 2008 08:16 PM
BLAZE GS
Sep 24, 2007 06:26 AM
zeanimal2001
1st Generation
Aug 29, 2007 12:27 PM
petro4411
Dec 5, 2005 01:42 PM
