7 bolt 6 bolt swap
Old Sep 23, 2007 | 02:32 PM
BLAZE GS's Avatar
Default 7 bolt 6 bolt swap
is there any thing i had to do diffent if the engine im going to put in is a 6 and mine is a 7? i pretty sure mine is a 7 because it was made sep of 1992. is there any modifing i will have to do?
Old Sep 23, 2007 | 02:35 PM
Default RE: 7 bolt 6 bolt swap
6 or 7 refers to GST/GST. If its not the turbo engine then that does not apply
Old Sep 23, 2007 | 02:38 PM
BLAZE GS's Avatar
ok there both non turbo
Old Sep 23, 2007 | 02:40 PM
There we go
Old Sep 23, 2007 | 04:00 PM
BLAZE GS's Avatar
but i have a non turbo 6 bolt that i plan on converin to a turbo.forgied pistons, rods, injecters ect.
Old Sep 23, 2007 | 04:29 PM
sk8dudety's Avatar
i believe that requires a new ecu and some other wiring stuff... not exactly sure though, but not very cheap
Old Sep 23, 2007 | 04:46 PM
BLAZE GS's Avatar
yea the ECU is about 200 bucks and wouldnt the stock wireing work? maybe not but i can get that also
Old Sep 23, 2007 | 06:46 PM
nick_200321's Avatar
if you are swapping to a turbo you will need both new ECU and wiring harness, possibley new mounts
Old Sep 23, 2007 | 11:02 PM
sk8dudety's Avatar
i dunno about new mounts, its the same motor just not a turbo lol... That wiring harness would be pretty rough to swap out, but it is doable... also, you might wanna think about beefin up the insides, along with the fuel, air, etc...
*sidenote: when sebba said it "refers to GST/GST"... he meant to say "refers to GST/GSX"*
Old Sep 24, 2007 | 06:26 AM
whats the point of dropping the 6 bolt in. You could just build up the motor that is in your car now. But you are gonna need lower compression pistons. Oh and check out www.vfaq.com. It shows how to turbo a NT 1g. It is not easy and IMO not worth it since there are so many turbo version around to buy
Bcr5165
1st Generation
Apr 26, 2011 11:26 PM
zeanimal2001
1st Generation
Aug 29, 2007 12:27 PM
bud660r
Aug 31, 2006 07:41 PM
petro4411
Dec 5, 2005 01:42 PM
antomx
Sep 29, 2004 02:32 PM
