1G eclipse.... will six bolt engine work on 7 bolt tranny?!!!! HELP PLEASE
Old Jul 1, 2008 | 06:35 PM
pawleywog66's Avatar
Default 1G eclipse.... will six bolt engine work on 7 bolt tranny?!!!! HELP PLEASE
I really need to know if there is any possible way to make a 7 bolt auto tranny to work with a six bolt engine (non-turbo 2.0 4G63).... i was told i might just be able to change the torque converter in the tranny and it should work but i need to no for sure!!!!!!! any help would be great!!!!!
Old Jul 1, 2008 | 06:54 PM
dsm1990gsx's Avatar
Default RE: 1G eclipse.... will six bolt engine work on 7 bolt tranny?!!!! HELP PLEASE
I'm not 100% sure but if you have a 1g, a 2g auto trans will not fit, the torque coverter is bigger in a 2g and the 2g trans is bigger. I'll look around and see if I can find any info on that.
Old Jul 1, 2008 | 07:01 PM
dsm1990gsx's Avatar
http://www.dsmtalk.com/forums/showthread.php?t=195077
This guy made an adapter kit to fit a 2g auto trans in a 1g soguess it can be done
http://www.kigglyracing.com/racing/index.htm
Old Jul 1, 2008 | 07:07 PM
Well man the car is a 1G..... but its a 93 which the 93 & 94 both had 7 bolt engines... mine blew and now i have a 6 bolt engine from a 91.... i need to know if that 6 bolt enginewill bolt up and work with my 7 bolt tranny.... like i said someone said i may just have to change the torque converter
Old Jul 1, 2008 | 07:30 PM
dsm1990gsx's Avatar
Oh duh sry I thought you were trying to put a 2g trans in your 1g lol. Try calling a mitsu dealer and see if the 1g 6 bolt and 7 bolt's have the samepart # torque converter.
Old Jul 1, 2008 | 08:12 PM
well i already know that the 6 boltmotor wont go into the 7 bolt torque converter....... but what i want to now is if i can just put the 6 bolt T.C. in to my 7 bolt tranny
Old Jul 1, 2008 | 08:16 PM
i also know that the TC's part # for the 6 bolt and the 7 bolt ARE different but i was told the only difference is where the crank goes into the TC's the 6 bolt's hole is a lil deeper for the 6 bolt engine crank shaft is longer than the 7 bolt
Cardav901
Jul 28, 2011 03:16 AM
2slow
Apr 22, 2010 01:27 PM
2slow
Mar 16, 2010 11:05 PM
99clipsgst
Mar 3, 2005 02:32 PM
