Burrrr no heat
Old Dec 16, 2005 | 07:11 PM
wsuweston's Avatar
Default Burrrr no heat
My 95 GS just quit producing heat. The moter is not overheating, changed thermostat. Has anyone else had a problem with this?
Old Dec 16, 2005 | 08:09 PM
shreff99's Avatar
Default RE: Burrrr no heat
heater core maybe?
Old Dec 16, 2005 | 08:43 PM
wsuweston's Avatar
When the core goes bad wouldn't it leak coolent inside the car? All my other vehicles have leaked in the cab.
Old Dec 16, 2005 | 09:19 PM
Sanguinius's Avatar
When was the last time you did a coolant flush? Possibly a clogged line in the system? Also check coolant levels low coolant also causes lack of heat.
Old Dec 16, 2005 | 09:30 PM
wsuweston's Avatar
The coolant is full, but I did have my valve cover gasket replaced. Could a piece of gasket gotten into the lines? It could be pluged. So when I drain the system should that remove the crap or do I have to have it blown out? Has anyone here removed a heater core from an 2nd gen? Also where are the in/out lines that go into the firewall for the core located?
Thanks
Old Dec 16, 2005 | 10:10 PM
Sanguinius's Avatar
All right first there isn't any way that valve cover gasket could get in the coolant lines unless you dropped it in while changing the thermostat. Don't drain the system get the prestone coolant system flush and do that first. It will give you instructions just follow them. If that doesn't fix it then you may have a serious clog somewhere .
Old Dec 18, 2005 | 10:05 AM
get435's Avatar
pull the lines off of the motor to the core flush lines out hook up the top on and put hose up to it if there is flow than the core should be fine and there is somthing cloged in head or block and that is a differant story.
Mitsudiam
Feb 3, 2006 11:21 PM
ad37@verizon.net
Oct 24, 2005 06:58 PM
ad37@verizon.net
Oct 23, 2005 03:08 AM
EclipseGS
Oct 12, 2004 02:39 PM
markm
Jul 10, 2004 04:09 PM
