IN CABIN BOOST CONTROLLER
Old Dec 22, 2007 | 10:38 PM
SPYDER97RED's Avatar
Default IN CABIN BOOST CONTROLLER
I WAS WONDERING IF I CAN RUN MY BOOST LINES INTO THE CABIN, WITH ANY MBC OR DOES IT HAVE TO BE MADE SPECIFICALLY FOR IN CABIN USE.
Old Dec 22, 2007 | 11:18 PM
silvercoupe97's Avatar
Default RE: IN CABIN BOOST CONTROLLER
Most in-cabin controllers use an eletronic rheostat or a long cable. Your boost controller should be attached as close to the turbo as possible, just like the BOV. You should only have to adjust your controller a few times if you tuning it for your preferred boost setting and you should only adjust it to match fuel output.
Please don't use caps, it's really annoying. We can read lowercase letters just fine.
Oh and welcome to MF.
Old Dec 23, 2007 | 12:20 AM
Natedogg89's Avatar
wow silver havent seen you in a while. About the boost controller though- There really isnt a need to have it in cabin, all it becomes is a temptation to turn it up higher and higher. GReddy makes a nice in cabin called the Profec B but its like $300. Not really worth it imo and how much do you actually need to change the boost? I havent touched mine since I set it at 14....Turbo XS does have whats called a "dual-stage" which allows to change between to different boost setting with a flip of a switch.
Old Dec 23, 2007 | 02:56 AM
Cant be bothered to post a reply, however, WELCOME BACK!!!!
Old Dec 23, 2007 | 07:37 AM
yea you really dont need it in the cabin because they are pretty good at staying constant.
Knaackers
Jul 17, 2004 08:55 PM
Knaackers
Knaackers
Jul 13, 2004 04:16 PM
Knaackers
Jun 25, 2004 08:14 PM
Knaackers
Jun 25, 2004 06:01 PM
