car bogging/ stuttering under hard acceleration?!?
Old Nov 20, 2006 | 05:32 AM
silvercoupe97's Avatar
Default RE: car bogging/ stuttering under hard acceleration?!?
As for the boost leak test. How much did you pressurize the ICP? Did you go up to 15psi? How long did it hold pressure before losing it? Did you spray couplers, TB, injectors, ect. down with soapy water? There's a leak somewhere, lol. 15hg is not normal on a stock motor. Do you have cams? 15hg is normal with cams. Also, Racer has a point, you should lower your boost down to at least 12-13psi on a big16g. That's a lot of air for the stock fuel. Yeah, I know, a lot of folks run that on the stock fuel system, but do you really want to risk it?
Is this a 1G or 2G? Are those all your mods? The ones that you listed?
Old Dec 2, 2006 | 06:45 PM
jerusry's Avatar
well i thought into it really hard, as to what i should spend my money on and i fixed it... i got a new battery and new iridium spark plugs and BAM!!! it runs like a champ now. thanks for your advice guys... i will get better fuel sending and a bov and boost controller... but now i gotta wait cuz i had to get tires and i have to replace two busted rims... just thought i should bump this up in case anyone is havin the sam problems... all it was is shot out spark plugs.. man, they looked nasty when i pulled them.
newoutlanderfan
Dec 13, 2011 09:01 AM
GIO_2.O
May 5, 2009 04:00 PM
Prince16
Mar 19, 2007 07:28 PM
ComposeEvo
Oct 18, 2006 01:35 PM
BrunoBoy650
1st Generation
21
Feb 18, 2006 04:28 AM
