car idleing funny
Old Jul 17, 2006 | 04:28 PM
boo426666's Avatar
Default car idleing funny
my car idles funny and stalls sometimes the diagnostics says its the idle control system so does anyone know what needs 2 be replaced?[sm=dontgetit.gif]
Old Jul 17, 2006 | 06:43 PM
Default RE: car idleing funny
Either your IAC (idle air control) sensor, or you just need to raise up your idle with the BISS (base idle set screw). I would try the biss first. It should be on top of the throttle body. I think that should do it
Old Oct 16, 2006 | 03:48 PM
bluballz07's Avatar
yeah try the BISS first my buddies was doing the same thing and that fixed his problem
Old Oct 18, 2006 | 04:02 AM
5Tizzle's Avatar
idle air control valve is about 220 bucks at napa
Old Oct 18, 2006 | 01:40 PM
N/Teclipse's Avatar
You can get a used one for about sixty bucks though, with a one year parts protection. Thats what I did when mine went bad and it has been fine for awhile.
Old Oct 18, 2006 | 10:41 PM
Dookitchen's Avatar
does it risky to install a used one? I got mine for 30 bucks.
Old Oct 19, 2006 | 10:38 AM
Nope not at all. If it does not work then no harm done.
Old Oct 19, 2006 | 05:58 PM
N/Teclipse's Avatar
Just make sure its clean along with where it goes in, and make sure the o-ring that goes around it is in good shape, and you should be fine.
BLAZE GS
Apr 29, 2008 06:41 PM
SILVER
1st Generation
Aug 11, 2007 01:21 AM
GotBoost
Jan 8, 2007 07:32 PM
BrunoBoy650
1st Generation
Apr 25, 2006 09:10 PM
99EclipseRS
Jan 20, 2005 03:57 PM
