Car/Shifter wont move?
I tried starting it in N, but as soon as I turn the car on the shifter will not move into any other gear. I have the clutch down and its still not moving into any gears. The shifter moves into any gear perfectly with the car off, but nonewith the clutch down and the car is on.
Ok, I put it in 1st and tried to turn it on it started to try and move a little stop move alittle and stopbut would not turn on fully, I tried it in 1st and held down the brake and it wouldnt not cut on at all.
ok, im almost betting either try to adjust it or a slave cylinder... my first gen did the same thing, only after i changed the the clutch, then i bought a new slave cylinder.. it didnt help but when i adjusted the clutch it was fine
tonyblu
May 21, 2011 05:47 PM
tomek
Sep 17, 2009 11:46 AM
