CAR WONT START!!! HELP
Old May 13, 2006 | 06:04 PM
Default RE: CAR WONT START!!! HELP
Well just because they are bad does not mean they wont spark. Just means they wont spark every time they are suposed to. I think it could be just one of them. Thats enough for it to stall.
Old May 13, 2006 | 07:35 PM
dreamz's Avatar
You could take your started to a autozone near by and have them take a look, A starter drains alot more voltage than your electronics so try checking battery if thats the case get some jumper wires and buddy car let engine run to charge battery
Old May 13, 2006 | 07:39 PM
dreamz's Avatar
well here another thought but I dont think this is the case since its summer but maybe your starter might have frozen up they usaly do this in winter but try banging it with hammer (softhead)
Old May 13, 2006 | 07:52 PM
Yea thats what i told a few people on here to do. Well if hes not hearing the click from the solenoid then whats the point?
Old May 14, 2006 | 05:10 AM
edgeofsane's Avatar
ORIGINAL: slow420a
ORIGINAL: edgeofsane
Is your mass airflow sensor hooked up?
that wouldnt keep it from starting
Great, now I feel like a jackass.
Old May 14, 2006 | 08:04 AM
My93EclipseGS's Avatar
Clean the battery terminals before you do anything. I have found on most cars that if your cables are dirty the car will not start. Start with the easy stuff Good luck
Stuck in the desert with no car
Wil
Old May 15, 2006 | 09:34 PM
Sanguinius's Avatar
All right let's start with the simple stuff. Clean terminals on the battery and ensure charge. Now once you are sure the terminals are clean and the battery is fully charged ensure all lights are off and attempt to start the car. Does the engine turn over at all? Does the starter go click click click? Is there no sound at all? The fact that everything cuts off and the car doesn't start says to me that you likely have a battery problem. That would be the first thing I check. Also if starting like that doesn't work and starting with someone trying to jump you doesn't work then take the negative terminal off the battery and hook the jumper cable up to the loose terminal and try to start like that. If it starts then the battery is toast and is absorbing more electricity than the person jumping you is making and you'll never get the car started (You MAY even kill his Alternator like that). Hope this helps a bit. Give me more info after trying these and I'll try to get you running again.
nutz
Dec 11, 2006 10:44 AM
mountaindewguy
Nov 18, 2006 12:16 AM
mountaindewguy
Nov 14, 2006 09:22 PM
tno1
Jul 8, 2005 02:36 PM
ldeemt
Jun 13, 2005 12:06 PM
