Cel p1390 ?
Old May 6, 2013 | 10:08 PM
thebat96's Avatar
Exclamation Cel p1390 ?
Hi all. In my 96 Eclipse I had an oil leak from the head gasket. Upon fixing that, I replaced the timing belt, head gasket of course, valve cover gasket, power steering pump, and water pump. When I started it up first time, I could hear almost a rubbing noise in the timing belt cover. After driving it first time, when I got the car up to 70 MPH my CEL came on. I checked it & it threw up P1390 - Timing belt skipped 1 tooth or more. Cleared that out and drove to/home from work. Again, when I reached 70 MPH the same code went up.
I've read a few threads but all with different answers. I'm hoping it's something as simple as making the comp 're-learn' using a DRB-III tool. All help appreciated - thanks
Old May 6, 2013 | 10:13 PM
Reset the ECU and check your timing one more time.
Old May 7, 2013 | 08:42 PM
thebat96's Avatar
^ tried that. It's still throwing up the same code every 5 minutes. Had it 5 times now.
Old May 7, 2013 | 08:49 PM
Try google. I found an article that may be of use to you.
Mitsubishi Eclipse DTC P1390
It seems like this is a common issue.
Old May 7, 2013 | 08:51 PM
thebat96's Avatar
Already searched that. Saw yesterday and read at least 9 forums on this & no fix
thebat96
Jul 7, 2014 11:40 PM
Damian Wolf
Sep 10, 2013 08:58 PM
cooltow1
Feb 22, 2011 10:34 AM
99ECLIPSMAN
Aug 18, 2006 07:44 PM
mitsu23
Oct 30, 2003 11:56 PM
