changin timing belt
what else should i change while im changing the timing belt, water pump and balance shaft belt or will that be good because i plan on upgrading the turbo either this summer or fall so if there is something else that needs to be changed or upgraded i would like to know while i have it apart right now
thanks
frantas
thanks
frantas
if your doin the timing belt do all the belts and you might consider changin the pullies while your in there and have it apart........ and always change the waterpump when changin the timing belt........
so timing belt balance, balance shaft belt, water pump, alternator belt, power steering belt, air conditioning compressor belt umm does this sound like all of the belts i should replace while i have my car apart?
judien
Mar 9, 2018 03:41 PM
marx88
Jun 30, 2011 03:54 PM
