clutch
Old Jul 18, 2005 | 12:36 AM
zaskar888's Avatar
Default clutch
i just bought a eclipse 99 gst and also learned how to drive a stick last week. i just noticed the clutch a lot softer when im cruising for 10 miles in 5th gear. when i try to clutch in that time the clutch is too soft. sometimes i cannot even go to neutral. i still need to struggle for awhile to get my clutch again so i can change gears.
Old Jul 18, 2005 | 03:03 AM
DSMTalonAWD51's Avatar
Default RE: clutch
it may just be in your head, youve only been driving stick aweek
Old Jul 18, 2005 | 03:08 AM
zaskar888's Avatar
Default RE: clutch
nope it really does that.
Old Jul 18, 2005 | 11:55 AM
get435's Avatar
Default RE: clutch
sounds like a slave or master is going out or evan the clutch.
Old Jul 19, 2005 | 12:37 AM
Default RE: clutch
if it was master/slave cylinder I would think it would do it anytime not just on the highway. If it does do it all the time though, check your clutch fluid resevoir, make sure its not losing fluid. pull back your floormat and look at where the clutch pedal goes through the firewall, check to see if theres any wet fluids there too. lastly, you could try bleeding the line, maybe you have an air bubble and its taking extra pump up to depress the clutch fully
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
