clutch
Old Nov 8, 2005 | 04:07 AM
zaskar888's Avatar
Default clutch
XTD STAGE 3 CLUTCH & FLYWHEEL /93-99 ECLIPSE /TALON FWD for $340 worth it? I only have a lightly modded gst eclipse
Old Nov 8, 2005 | 09:50 AM
Sanguinius's Avatar
Default RE: clutch
Depends what you're planning on doing. A stage 3 for light mods?? I'd go with a lower stage. Probably a 1 or 2 unless you intend to in the near future make it a massive power plant. Also you have to look into what the clutch is designed to handle not merely the "stage" it is. Approximately what is the power your engine is making now and what is the clutch you want rated at. Also remember the high stage clutches are set for racing which means fast takeoffs and hard shifting. Therefore are going to be INCREDIBLY difficult to run on the street. But if you intend to make a track terror then go for it.
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
