Clutch Fluid Leaking?
Well here is some more **** for me to worry about, i was told i have a clutch fluid leak, i dont have any idea where to check the fluid level or were/how to check for leaks....any help?
UPDATE- i did refer to the trusty manual and found where the fluid is located but i still dont know where the main spots are to check for leaks?
RE: Clutch Fluid Leaking?
I would check the lines down to the left side of the motor.. If you dont find it by automotion time, bring it down and there will be some people at my place that will be able to help ya for sure.. But I would start with the lines.. Have you replaced any of them or are they all stock lines still?
As far as i know they are all stock. tomorrow i will have a look around but i dont really know what i'm looking for...ill just look to the left of the motor like you said and see if i can locate anything. I'm staying at the Shamrock, just made reservations last night, but ill have to get ur phone # or something to locate you when your there and you can take a look!
ok ill try it tomorrow and see if anything happens. yeah the place is across the street from noahs ark, right on the main drag...you make reservations yet? there wasnt much if any room left at the 5-6 places I tried.
Thats right your from Baraboo so you will probably be staying at your house. nevermind then
jcasaccio
06-06-2006 06:14 PM
