Clutch Fluid Leaking?
Old May 7, 2007 | 06:25 PM
Natedogg89's Avatar
Default Clutch Fluid Leaking?
Well here is some more **** for me to worry about, i was told i have a clutch fluid leak, i dont have any idea where to check the fluid level or were/how to check for leaks....any help?
UPDATE- i did refer to the trusty manual and found where the fluid is located but i still dont know where the main spots are to check for leaks?
Old May 7, 2007 | 09:36 PM
tjbiker031's Avatar
Default RE: Clutch Fluid Leaking?
its the smaller resevior next to the brake on the right
Old May 7, 2007 | 09:40 PM
could be the clutch master cylinder, slave cylinder, or just one of the fitting on the lines
Old May 7, 2007 | 09:45 PM
TheAdvocate's Avatar
I would check the lines down to the left side of the motor.. If you dont find it by automotion time, bring it down and there will be some people at my place that will be able to help ya for sure.. But I would start with the lines.. Have you replaced any of them or are they all stock lines still?
Old May 7, 2007 | 11:21 PM
Natedogg89's Avatar
As far as i know they are all stock. tomorrow i will have a look around but i dont really know what i'm looking for...ill just look to the left of the motor like you said and see if i can locate anything. I'm staying at the Shamrock, just made reservations last night, but ill have to get ur phone # or something to locate you when your there and you can take a look!
Old May 8, 2007 | 12:33 AM
Hmm, I dont recognize that place... Do you have a puddle under your car when its parked? Start it up and push the clutch in and out.. See where the puddle forms under the car...
Old May 8, 2007 | 12:38 AM
Natedogg89's Avatar
ok ill try it tomorrow and see if anything happens. yeah the place is across the street from noahs ark, right on the main drag...you make reservations yet? there wasnt much if any room left at the 5-6 places I tried.
Thats right your from Baraboo so you will probably be staying at your house. nevermind then
newoutlanderfan
May 27, 2013 10:47 AM
cptkid570
Nov 15, 2007 07:09 PM
davidmitsusrock
Aug 4, 2006 01:05 AM
jcasaccio
Jun 6, 2006 06:14 PM
sarahs99
Mar 1, 2006 11:01 AM
