CLUTCH! GRRR
Old Dec 23, 2007 | 01:45 AM
victim619's Avatar
Default CLUTCH! GRRR
ok, been gone a while the car is a 99 spyder gs
anyways im doing the head swap soon (4g63), so i need a clutch too support the power it will make after the evo 3 kit.... Anyways, my stick has been hard to shift latley and my clutch got stuck and it rode 4000 for like 5 seconds (don't ask how haha) and since then its smelled like burnt clutch. I guess I need to replace it... Any ideas of what I should get since im doin things little by little so eventually ill make my goal 300whp but until then im doing things little at a time. Suggestions please....thanks
Old Dec 23, 2007 | 12:29 PM
dorian7's Avatar
Default RE: CLUTCH! GRRR
ACT clutch 2100 or 2600 with street disc
Old Dec 23, 2007 | 01:36 PM
victim619's Avatar
Whats the difference between the 2 and where do I buy this at. Ive seen them on random websites but I want a good website. Do I need to find a 4g64 one or does it really not matter if I get the 4g63?
Old Dec 23, 2007 | 02:05 PM
Natedogg89's Avatar
2600 will hold more power than the 2100. 2600 requires more leg power to push the pedal down than the 2100.
Old Dec 23, 2007 | 02:40 PM
victim619's Avatar
Whats the power difference? and will it matter if I'm currently running just an exhaust not other mods therefore im not creating that much power, but will in the future. Any website to buy this and the 4g64 ones are hard to find will the 63 work?
Old Dec 23, 2007 | 05:10 PM
dorian7's Avatar
Here are the models that will fit on your 64 http://www.advancedclutch.com/1356667/0/0/0/1999_MITSUBISHI_ECLIPSE_SPYDER_L4_2.4L_N_FI_(4G64) .html
I have the 2600 and it took a little while to get used to but I don't think it's that bad at all, I got mine off of ebay and it was cheaper than the online stores, but you HAVE to make sure it is a real name brand ACT clutch, make sure the seller has a good rep too. If you are planning on doing a lot of mods it is probably best to do the 2600. The 2100 is rated @ 330 ft/lbs of torque and the 2600 is rated @ 400 ft/lbs.
Sebba
Aug 31, 2007 12:06 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
