clutch problem
Old Aug 22, 2006 | 01:50 AM
98eclpsrider's Avatar
Default clutch problem
Have any of you gotten a heavier clutch and is now harder to disengauge it fully now? i had that and i put a slave cylinder extension rod in to make it fully disengauge, but i barly have any play now with my clutch now, and i want some more play. Is there anything out there, like an extension rod for the master cylinder? besides getting a new master cylinder??
Old Aug 22, 2006 | 09:30 AM
Default RE: clutch problem
Have you tried just adjusting the screw at the pedal, cuz i know when i put in the ACT 2900 it was very short and there is a bolt behind the pedal that will give you alittle more pedal to work with.
Old Aug 22, 2006 | 01:19 PM
DSMTalonAWD51's Avatar
no clutch NEEDs an extension rod, and all they do is put more stress on your thrust bearings. if you cant fully engage/disengage it, just adjust the pedal. there are 2 adjustments, most people just adjust the lower part but you can also adjust the top of the pedal, sounds like what you need to do
Old Aug 22, 2006 | 01:37 PM
i just adjusted the screw in the pedal i didn't adjust the pedal yet, i'll try that one.
Old Aug 22, 2006 | 02:19 PM
ORIGINAL: 98eclpsrider
yea what youll see is a bolt with a nut on it. You have to loosen the nut, then turn the bolt to where you want it, then tighten the bolt.
Old Aug 22, 2006 | 02:24 PM
and that will help it disengauge a little better and have more play?
Old Aug 22, 2006 | 02:30 PM
yup
Old Aug 22, 2006 | 02:36 PM
Thanks man, for me it's annoying to have the pedal two or 3 inches of the floor. i like to have some play.
Old Aug 22, 2006 | 02:38 PM
yup i had the same thing, actually mine was so low i couldt even get the clutch to fully disengage. But make sure that you tighten that nut back on good because i had a problem with mine where it kept loosening and making the clutch pedal lower again.
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
