Clutch question
Old Apr 8, 2007 | 09:18 PM
n2daizo123's Avatar
Default Clutch question
I have a 97 eclipse with the 420 in it. I recently installed a fidanza clutch and flywheel and now the transmission grinds and the clutch pedal has to be pressed ALL the way to the floor to disengage the clutch. Any ideas on why this is happening? the clutch is the 4.2 fidanza clutch. Could the slave cylinder be causing the problem?
Old Apr 9, 2007 | 02:55 AM
Nubiebubie_GSX's Avatar
Default RE: Clutch question
Bleed your line just to be sure there no air. I do not know much about the setup of the 420A clutch/pedal system, but if it looks like this http://www.roadraceengineering.com/c...ywheeltech.htm The suggestion would be to adjust your pedal and bring up the engage/disengage point. Just scroll through the page. All in expensive experiment to try. If it don't work guess u got to wait for somebody more experience to jump in lol and give advice.
Old Apr 9, 2007 | 09:38 AM
Its your clutch pedal. Its common with any car that you install an upgraded clutch into that you have to adjust the engagment point. Behind the pedal youll find a rod and toward the firewall end of it is a nut. Just loosen the nut a little, then turn the rod to screw in or unscrew. I dont remember which way you need to go, in or out. i would think out since your engagement point is low, but just play around with it. Once you turn it just tighten the nut back and check
Old Apr 9, 2007 | 12:26 PM
silvercoupe97's Avatar
Yup, that RRE link is what I always give when someone states "new clutch" and something about it's engagement, lol.
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
