clutch question
clutch question
i drive a 97 gst and my clutch is finally starting to go so i was going to replace it with an act 2100 w/street disk, is there anything else i need to buy to go with this ???
http://www.slowboyracing.com/product...cat=104&page=1
direct link to what im buying
changed my mind gettin the 2600. still, anything i need to pick up other than that? i heard something about an oil line and do i HAVE to get a new, or resurface, my flywheel? cuz im kinda short on funds :/
How many miles are on the car and when was the last time the clutch was changed? I know money is tight, but while you're in there you should replace the pivot ball and shift fork. If I was you I would be sure to have grease on hand as well to lube the pivot points. Also, you might want to consider replacing the axle seals since you may mess them up since you have to pull them out to pull the tranny.
97spydergs
10-29-2007 02:14 PM
wicked2407
10-25-2006 06:07 PM
