clutch question
Old Jan 20, 2010 | 01:23 AM
c577's Avatar
Default clutch question
i drive a 97 gst and my clutch is finally starting to go so i was going to replace it with an act 2100 w/street disk, is there anything else i need to buy to go with this ???
http://www.slowboyracing.com/product...cat=104&page=1
direct link to what im buying
Old Jan 20, 2010 | 01:29 AM
c577's Avatar
changed my mind gettin the 2600. still, anything i need to pick up other than that? i heard something about an oil line and do i HAVE to get a new, or resurface, my flywheel? cuz im kinda short on funds :/
Old Jan 21, 2010 | 03:01 PM
c577's Avatar
wow this forum is dead.
Old Jan 21, 2010 | 06:36 PM
id have the flywheel resurfaced. But other than that you should be fine
Old Jan 21, 2010 | 06:52 PM
dsm1990gsx's Avatar
Like TE said just get the flywheel resurfaced.
Old Jan 22, 2010 | 07:24 AM
oh_what_up's Avatar
How many miles are on the car and when was the last time the clutch was changed? I know money is tight, but while you're in there you should replace the pivot ball and shift fork. If I was you I would be sure to have grease on hand as well to lube the pivot points. Also, you might want to consider replacing the axle seals since you may mess them up since you have to pull them out to pull the tranny.
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
