Cold Start Squeal... PLEASE HELP...
Old Sep 18, 2007 | 10:38 PM
ibbster's Avatar
Default Cold Start Squeal... PLEASE HELP...
I have a 1998 GSX and when i start the car when its cold there is a squeal that lasts for about 5 - 10 seconds from one of the accessory belts ... the squeal only happens on a COLD car ... but when i start the car when it i sWARM there is no squeal... Does any one know something that will help me get rid of the noise...the squealing seems to be coming from the beltthat runs on the power sterring pump.....any help would be apprecaited...
thanks
Old Sep 19, 2007 | 12:14 AM
jerusry's Avatar
Default RE: Cold Start Squeal... PLEASE HELP...
get a new belt... it has stretched a bit over time, and since it is colder the belt is not as soft so it allows it to slip a bit under load until it warms up or is free of the load... it shouldn't be too hard or too expensive either.
Old Sep 19, 2007 | 12:16 AM
You can replace the belt.. or spray a little WD-40 on it : )
Old Sep 19, 2007 | 06:57 AM
ORIGINAL: Sebba
you and your wd-40. Do you put that on food for seasoning as well
Old Sep 19, 2007 | 07:25 AM
Yessir : )
Old Sep 19, 2007 | 08:42 AM
sk8dudety's Avatar
yea wd-40 or some sort of belt dressing you can pick up from autozone or advance auto,, spray it on the sides of the belt that actually touch the pulleys and see what happens, that could be a fix. but if it persists then yea just replace it
Old Sep 19, 2007 | 11:54 AM
RCJr9186's Avatar
Can of WD-40 = 3 bucks
New belt = apx 12 bucks
no more squeel
priceless
Old Sep 19, 2007 | 04:54 PM
tjbiker031's Avatar
b4 you just start throwing wd-40 on your belts, inspect them, mine were doing the same thing and i look at it and i had a 4 inch tear down the belt.
Old Sep 19, 2007 | 06:11 PM
jerusry's Avatar
just get a new belt. you will need one eventually anyways...
Old Sep 20, 2007 | 07:59 AM
RCJr9186's Avatar
why would you do a "quick fix" on a 12 dollar part? ok.... 12.75 w/ tax and 10 mins of time.
