coolant leak after rebuild
OK Spyder GS 2.4 is running but now I have a coolant leak. It's dripping down past the Oil Pump and dripping off an oil pump bolt next to the oil pan. Water pump doesn't appear to be leaking around the seal. Before I start ripping things out again, anyone have any ideas? I'm thinking maybe the rubber o-ring that seals the metal water inlet pipe isn't properly seated. Will wait for engine to cool to check it because if it's leaking on the bottom where I can't see.Then I'll need to remove the exhaust manifold to get to it. SUX
wega
Sep 30, 2007 11:48 PM
