crank walk price fix?
Old Mar 17, 2006 | 01:17 PM
novetek's Avatar
Default crank walk price fix?
what is the avg cost to fix crankwalk
Old Mar 17, 2006 | 03:50 PM
Sanguinius's Avatar
Default RE: crank walk price fix?
You're talking about an engine rebuild... If nothing else it'll be AT LEAST a full bottom end rebuild...
Old Mar 17, 2006 | 04:21 PM
ORIGINAL: Sanguinius
which will not always cure it 100% from what I understand. I think the only true cure is the 6 bolt swaps or the sonata swaps
Old Mar 17, 2006 | 04:59 PM
Sanguinius's Avatar
If what I read is right the crankwalk is a problem with either misaligned or badly seated crank bearings... So if those are replaced shouldn't they be seated right the 2nd time around? Which theoretically SHOULD fix the problem right?
Old Mar 17, 2006 | 07:39 PM
no the problem is with oiling the squirters and there location that cause the crank to walk. At least that is the way I always heard it.
Old Mar 19, 2006 | 03:31 AM
Sanguinius's Avatar
Might be something to look into then... I always heard it was the journal bearings on the crank being misaligned thus allowing it to move... I also heard that it was only the Detroit made engines that had teh problem. Thus the reason all 7 bolts are susceptible to the crankwalk but some will never suffer from it... I had always read it was a factory problem
player69x
Jan 25, 2006 09:45 PM
dreamz
Dec 4, 2005 09:53 AM
jess240
Dec 2, 2005 06:57 PM
silverspyder
Feb 24, 2005 12:13 AM
wildwest
Jul 9, 2004 11:54 AM
