Crankwalk
Old Dec 3, 2006 | 04:49 PM
  #81
BlackMurcielago's Avatar
Default RE: Crankwalk
Also there is oil on the bottom of the car on the frame. Im no expert on DSM's but thats not where oil is supposed to be is it?
Old Dec 3, 2006 | 09:03 PM
  #82
93eclipsegsx's Avatar
well where is the oil leaking from? you're right on the oil not being there.
Old Dec 4, 2006 | 12:03 AM
  #83
Im not sure i looked in through the bay and could not see it. Im a small person but not small enough to under the car without lifting it . I have those famous yellow ramps but i have no clue how to get it on there with out strting that car. Any ideas and im not going undder there with the car on a jack, **** that im not getting crushed lol
Old Dec 4, 2006 | 12:07 AM
  #84
estraw's Avatar
buy a set of jack stands. they should only cost like 30 bucks at most for a good enough set. just jack up the car and put it on stands and it will be a lot safer then just the jack and probably safer then the ramps too
Old Dec 5, 2006 | 12:16 AM
  #85
Okay the guy down the street has a fun blown garage with a pit so im going to ask if i can use it for means be. But if its not a spun bearing, iv hit ****s end on ideas. Im in high school with no car and a girlfriend lol its fusrating s you could probably tell and WTF my work just closed for a month out of the blue. But to everyone who has spun one what was the damage report on you and the cost so i cold start getting figurs together
Old Dec 5, 2006 | 08:42 PM
  #86
Sanguinius's Avatar
When you spin a bearing as long as it's not run long you can likely salvage the engine. It will require at LEAST a lower end rebuild if not a little more. But first need to figure out the cause of the sound.
Old Dec 6, 2006 | 12:46 AM
  #87
Okay please pardon my stupidity but rebuilding the bottom would consist of a new crank, rods, and pistons?
Old Dec 6, 2006 | 02:36 AM
  #88
racerx55's Avatar
sometimes you can get away with having the crank turned and bearings, sometimes just throw a bearing in it & go, more often than not it trashes the crank and rod
Tom Piantanida
Apr 21, 2006 11:41 PM
RCJr9186
Apr 20, 2006 07:12 PM
TheEngineer
Jan 26, 2006 09:58 AM
congonator
Dec 21, 2005 11:26 PM
petro4411
Nov 29, 2005 06:06 AM
