door handle issue
Old Feb 1, 2011 | 07:28 PM
darkgoku's Avatar
Default door handle issue
hi guys, my driver side door won't open from the outside buy works from the inside, any idea what's causing it and what i can do to fix it? Thanks.
Old Feb 2, 2011 | 12:12 AM
The Bassist.'s Avatar
Is the outside door handle...engaging? Like does it feel like the door *should* open by pulling on the handle?
Try taking the door panel off and seeing if everything's attached in there. I'll warn you, it can be a real pain, I had to replace my passenger side handle, but hopefully you will just be able to reattach the rod that does the opening. Oh, I'm remembering... there is a white clip that swivels around on the handle. I believe the copper rod snaps into that.
I'm going off of memories here, but I hope it helps.
EDIT: The inside one works because it is a separate deelio from the outside handle that opens the door.
Ethan.
Old Feb 20, 2011 | 06:35 PM
djfrog2001's Avatar
Definitely check it out but you may have to replace it (and it is a right pain in the a$$). I don't know if that is a common problem with the 2G Eclipse models but I have had to replace mine twice in the last 4 years (97 RS) and I'm pretty sure I was yanking up on the handle every time I open the door.
Old Dec 23, 2011 | 07:33 PM
bigmusic's Avatar
Default Hi there I am having a disaster problem
I have a 1997 Mitsubishi Eclipse Spyder. I was on Holidays and when I came back I found that both door handles on my car were broken. I can not open, enter or get into the car in any way. What can I do. I lifted the latch and see that the mechanism is detached but more than that there is a little plastic thing inside but it does not seem to open the door. HELP HELP HELP.
G
elfrost
Oct 24, 2006 02:54 PM
elfrost
Sep 26, 2005 06:02 PM
99eclipseguy
Dec 23, 2004 01:30 AM
dafever
Jul 19, 2004 01:30 PM
97Eclipse
Dec 3, 2003 04:57 PM
