Drive without a Balance Shaft belt???
Did you read the link I gave you abt the timing belt procedure?
Hi i have a 97 Talon TSi turbo i was siting at a light and my car just died. Got out and looked and my balance shaft belt broke, going into my timing belt i believe because when i pulled the cover on the timing the belt was still on but ripped up a little. I was wondering if there any way to tell if i bent a valve with out pulling the head? And is i worth just trying to put a new belts on?
If you don't see bent valves, put your belt back on and then do a compression test to make sure you didn't bust a piston instead.
