Drive without a Balance Shaft belt???
Old Mar 14, 2010 | 02:28 PM
  #21
motoxxx87's Avatar
Right i know that but on the cam gears marks were are the ones that they are spouse to line up with? are the on the head???
Old Mar 14, 2010 | 04:25 PM
  #22
dsm1990gsx's Avatar
Did you read the link I gave you abt the timing belt procedure?
Old Jun 15, 2022 | 01:38 PM
  #23
JSHERRON's Avatar
Hi i have a 97 Talon TSi turbo i was siting at a light and my car just died. Got out and looked and my balance shaft belt broke, going into my timing belt i believe because when i pulled the cover on the timing the belt was still on but ripped up a little. I was wondering if there any way to tell if i bent a valve with out pulling the head? And is i worth just trying to put a new belts on?
To check the valves, all you do is pull the valve cover off, pull the rocker shafts off to get the pressure off all the valves. Then look at the valve stems. If they're all the same height you're good. If you see one or more that are short, start pulling the head. You have bent valves.
If you don't see bent valves, put your belt back on and then do a compression test to make sure you didn't bust a piston instead.
99clipsgst
Aug 5, 2008 10:13 PM
98gstspy
Feb 6, 2008 09:35 AM
racerx55
1st Generation
52
Dec 15, 2006 04:40 AM
bg23248
May 27, 2006 08:39 PM
93eclipsegsx
1st Generation
Mar 5, 2006 12:13 PM
