EGT Gauge or wideband?
Old Mar 14, 2007 | 01:15 AM
Natedogg89's Avatar
Default EGT Gauge or wideband?
So I have another spot left in my pod and i do plan on doing some sort or turbo upgrade in the future. What would i be better off to put in there? A EGT or just go with a uego wideband for tuning? I know the wideband is more money but i'd rather just buy it now than to get a egt only to find out i need a wideband anyway.....
Old Mar 14, 2007 | 01:39 AM
Default RE: EGT Gauge or wideband?
Wideband
Old Mar 14, 2007 | 01:46 AM
Natedogg89's Avatar
ORIGINAL: Sebba
Wideband
So the EGT isnt even worth it then? Anything else I should put in besides boost/wideband that would be useful?
antlip's Avatar
Wideband.
Old Mar 14, 2007 | 03:48 AM
Heres how it works. The Wideband displays your life a/f ratio right? So that is what is best for tuning... because that is exactly what you are tuning... the fuel mixture.
The EGT is an indicator that something is wrong. Too hot = lean etc... the only problem with that is that it takes a while for the heat to build up so there is a delay. Not the best of indicators.
The wideband will show any problems instantly
Old Mar 14, 2007 | 12:49 PM
RCJr9186's Avatar
well the EGT's of the car will tell you whether you are running rich or lean so yes, you can use an EGT gauge for tuning but it's much better to use a wideband. so the Eugo gets my vote also. you say a turbo upgrade i the future... do you have a boost gauge yet? if not AEM also has a Tru-Boost gague and when those 2 gagues are next to eachother it looks BAD@$$!!
Old Mar 14, 2007 | 01:36 PM
and a boost and wideband should be enough for anything youd need.
silvercoupe97
Aug 8, 2007 10:17 PM
95420A
Jul 3, 2007 06:15 AM
agallardo
Feb 22, 2007 03:47 AM
agallardo
Feb 20, 2007 11:19 AM
