Electrical question regarding the radio
Old May 26, 2006 | 10:06 PM
MissFox98Spyder's Avatar
Default Electrical question regarding the radio
When I am driving the power to my radio will cut in and out. The rest of the interior power is fine. First guess, a loose wire behind the unit. Are there any other possiblites?
Old May 26, 2006 | 11:08 PM
93eclipsegsx's Avatar
Default RE: Electrical question regarding the radio
you got a weak battery that doesnt supply the amps needed to run it maybe, is it an aftermarket stereo or stock, how many amps is your battery rated for?
Old May 27, 2006 | 12:36 AM
03gteclipse's Avatar
possibly bad fuse
Old May 27, 2006 | 01:40 AM
Evil1993Eagle's Avatar
ORIGINAL: 03gteclipse
possibly bad fuse
If you had a bad fuse it wouldn't work at all. Sounds like a bad connection to ground or something.
Old May 27, 2006 | 07:39 AM
ORIGINAL: Evil1993Eagle
possibly bad fuse
good point....
Old May 27, 2006 | 10:12 AM
If it was my battery, why would only the radio have the issue? I am thinking it has got to be the wiring. Where should I begin though? Now that I think of it, most of the time it happens, is when I tap the break or am sitting at idle.
Old May 27, 2006 | 11:57 AM
estraw's Avatar
ORIGINAL: 93eclipsegsx
well i had a problem like this before, i had a piece of crap battery in and only my headlights didn't work right. i put a stronger battery in with about 200 more amps and it works just fine now
Old May 27, 2006 | 08:48 PM
Check for any bad or loose grounds.
Gyella
Mar 26, 2013 07:29 PM
luvmylancer
May 25, 2010 01:42 PM
fastlane_lancer
May 31, 2008 10:10 AM
DeathCabForCutie
May 21, 2006 03:58 PM
deltadawn
Jun 18, 2005 10:37 PM
