engine question
ORIGINAL: sk8dudety
you're off to a good start, and yea i would totally go with the 6-bolt, that way you have no worries about crankwalk... also i believe they might be a bit easier to time? as far as gettin 350 heres a basic list: Evo3 16G turbo, bigger injectors, fuel pump, intake, exhaust, ported exhaust manifold and o2 housing, and downpipe, and you should be good, add stuff guys if im missin anything (and yes i know the ported exhaust mani and o2 housing isn't necessary, but it helps
![Smile](https://mitsubishiforum.com/forum/images/smilies/smile.gif)
Look, if you're wanting that much horsepower, the MOST important thing would be to do maintenance. It might not seem like a lot, but it is. Trust me. Those old parts wear a lot quicker when you've got hundreds of horsepower over stock. If you want your car to last, be clean, and respected, rebuild it right - the first time. Replace all the worn out stuff: Axles, brakes, coolant lines, etc. In the mean time you can research what you'll need, and save money for the motor. You'll learn more, and waste less money because you'll know exactly what you'll need when it comes time to swap.
ORIGINAL: nje95gst
i have heard the samething about crankwalk with automatics and thats y i was just wondering if it was worth it to even buy the 6 bolt or to just rebuild the 7 bolt that i have. pushing 350 is pretty much perfect for me. i dont think 500 would be typical since my baby is a daily driver. basically im just try to figure out where to start. so far the only thing that i have done is the suspension (kyb agx with tien s techs). if that 6 block mentioned earlier is still up for grabs, ill totally buy it, well depending on price obviously. as for what i need, to tell you guys the truth im lost. like i said earlier, pushing 350 is perfect, i just dunno what i need in order to make this happen. i already plan to get a greddy evo 2 exhaust and type rs bov, as well the injen short ram air intake system. any suggestions on where i can go on from here and what i should go out and buy would help me out a lot.
ORIGINAL: TSG59_Steve
I really hate the guy's that post all the hear-say, aka most of the 2g guys on here. More then likely he will need to port the exh. mani and o2 because if he upgrades the exhaust like you told him he'll get boost creep on his new motor. You also didn't say anything about fuel-management.
ORIGINAL: sk8dudety
ORIGINAL: sk8dudety
you must of missed the parts where i said "do research on all the parts", and "add stuff if i'm missing anything", and also "he doesn't HAVE to port the o2 and mani, but it's definitely a good idea"... and as far as maintenance i figured that was an implied thing. you cant exactly go upgrading your motor if you have parts that are broken or worn out. So im not sure what part of what anybody said was hear-say...
ORIGINAL: sk8dudety
2. You didn't say anything about maintenance, it's not something that's just implied. People go out and throw turbo's on their car without even thinking about spark plugs, wires, hoses, belts, harmonic balancer. So yes, you can go upgrading your motor if you have worn parts.
3. Have you got 350whp on a 16g?? I don't think you have, that's HEAR-SAY.
4. I wasn't necessarily even pointing you out specifically, a lot of people on this site think they can give advice. Suggesting strokers to someone who doesn't have a clue for example. If he has to ask, he's not to that point yet.And it's not even that I have a problem with THEM,it'sjust that they'll happily give suggestions about things they've never done.If I haven't done something myself or had first hand experience with it, I stay out of it.
GSXEX Knubbe
05-18-2007 07:57 AM
Kean2004
11-30-2005 03:50 PM
