exhaust?????
Old Mar 7, 2006 | 12:55 AM
Sanguinius's Avatar
Default RE: exhaust?????
You mean galvanized? Stainless is supposedly alot more corrosion resistant... I don't know where you could go to get proof but I wouldn't be worried about it...
Old Mar 9, 2006 | 03:14 AM
DSMTalonAWD51's Avatar
hearing an internet clip will not tell you much
Old Mar 10, 2006 | 02:09 PM
mysterio2099's Avatar
DSMTalonAWD51 is right. Unless you have some expensive studio quality mics set up to record the sound of the exhaust, it wont sound that great. Plus you have to think about where the mic is positioned during the recording. Is it close to the muffler, or 20 feet away? It will be nothing like in person.
...........Get a GReddy exhaust (personal opinion)
Old Mar 11, 2006 | 03:52 PM
ive always been a fan of the apex, an heres why. you can find em generally much cheaper than hks/greddy. its a quality exhaust(not that the others arent) but it flows more, it is a bigger exhaust (starts out at 3" at the cat, expands to 3.3" at the end. and most importantly, when you upgrade to a larger cat and downpipe(which you really need to do to make good power) apex already makes a bolt up downpipe, or roadraceengineering also fabricates 3" downpipe/cats to bolt right up to the apex n1 only. with the greddy or hks you are most likely going to have to pay someone to cut/weld a custom setup for you, which means that not only will it cost more, but its not reversable.
Old Mar 11, 2006 | 04:13 PM
My GReddy EVO2 is a bolt on Catback with a 4" tip. Cost about 480 bucks, plus a 50 dollar exhaust shop installation because I didn't have the tools to do it myself. It didn't require any welding either.
Old Mar 11, 2006 | 04:38 PM
ORIGINAL: mysterio2099
ya because you only have a cat back....but if you want a DP and TP you would need to weld and cut.... cack backs are direct fit bolt ups
Old Mar 11, 2006 | 07:07 PM
an also 3.3" at the back doesnt mean the tip, it means the pipe diameter. the n1 tip is 4.5in
Old Mar 12, 2006 | 01:38 AM
where does the exhaust change. I have never heard of piping for a catback just randomly changing to 3.3"
Old Mar 12, 2006 | 06:11 AM
well thats what it does. its not random, its engineering. eshaust gas is hotter closer to the turbo, so pipe diameter isnt as criotical since it wil travel faster. as the gases get closer to the end of the exhaust, they are cooler in temp, travel slower,and a progressively larger diameter pipe helps them to continue through
Old Mar 12, 2006 | 09:33 AM
ORIGINAL: TheEngineer
John it is Apexi it kind of flares a little as the pipeing makes its way back
