fan doesn't work, radiator heatsoak
Old Aug 22, 2007 | 02:37 PM
X Treme's Avatar
Default fan doesn't work, radiator heatsoak
Whats up guys...
My radiator fan on the turbo side does not work and is causing me to run higher temps, but I havent overheated. I looked and the fan is still pluged in and wires look fine. I'm lost, anybody got any solutions to help me?
Old Aug 22, 2007 | 03:23 PM
Default RE: fan doesn't work, radiator heatsoak
Thermostat.
If you want to keep temps down, when you turn the a/c on the fans should kick in
Old Aug 23, 2007 | 09:57 AM
chopper1's Avatar
One fan is automatically triggered when the A/C is cut on. The other will kick on with the temp. sensor.
Turn key on and turn A/C on. One fan should run. If it works, try switching the relay for the fans or one not important, and see if that is the problem. If it don't run, try switching the relays.
Temp. switch, Relay, Fuse, Fan. Process of elimination.
Old Aug 23, 2007 | 11:01 AM
atown420's Avatar
i always wondered why i could never seem to see my other fan on just the one. you guys answered my question and i didnt even have to post you guys rock!
Old Aug 23, 2007 | 04:23 PM
Chopper, from my experiance the A/C turns on both... i have never seen anything different. At least not with Mitsu
Old Aug 24, 2007 | 12:06 AM
X Treme's Avatar
I tried the ac but the fan didn't turn on. Does the car have to be on or just the key. Anyway, I was low on coolent (this was odd) filled it and i'm good to go.
Robods
Aug 22, 2010 08:00 AM
helidix
Nov 23, 2007 05:50 PM
salazar44
May 16, 2007 01:09 PM
hoosierdaddy_87
Jul 5, 2006 03:05 PM
eclipseonjuice
Feb 12, 2006 01:11 AM
