first time driving and it died need help
Old Oct 5, 2007 | 08:16 AM
kenlrw39's Avatar
Default first time driving and it died need help
ok i got a 96 eclipseand myfirst time driving it yesturday and it died. i've check the battery and it's good i had the altanator checked and it's good, changed fuel filter and thefuel pump works fine i had fuel at the rail, and i had spark on all 4 spark plug wires. so i need help with some ideas on what i should check next. Then my next question is i have the 2.0 420a motor but on mycam gears itsay 2.4L on them and there almost twice the size of my timing belt is that normal?
thanks
Old Oct 5, 2007 | 09:36 AM
Default RE: first time driving and it died need help
What is it doing when you try to start it?
Old Oct 5, 2007 | 09:45 AM
kenlrw39's Avatar
when you try to sart it it turns over but very slow
Old Oct 5, 2007 | 09:48 AM
did the car die while driving or is it just not starting. Maybe its your starter? Also check to make sure the timing marks no the gears are correct so that its not off. And the other thing it might be is the coil pack. Check the voltage on that
Old Oct 5, 2007 | 09:59 AM
kenlrw39's Avatar
it just died while driving i drove it to the gas station fine then after a few hours went to drive it again and got 4 blocks from my house and it died. and baout the gears are they suppose to say 2.4L on them?
Old Oct 5, 2007 | 12:16 PM
just out of interest is this a spyder? If not then i dont know why it would say 2.4L Could you maybe get a picture of the cam gears
Old Oct 5, 2007 | 12:23 PM
kenlrw39's Avatar
no it's a coupe i'll try to get a pic when i take off the cover. i think i found the problem i took out the starter and had it checked at autozone and they said the starter didn't have enough torque to turn the engine and the gear was getting stuck out do you know if this gear getting stuck would cause the car to die while driving?
Old Oct 5, 2007 | 12:49 PM
kenlrw39's Avatar
oh and to add to the cam gear part they both say "front" on them too.
Tmans20
Jul 14, 2014 10:05 PM
svetter84
Aug 7, 2012 08:06 PM
Gerard
1st Generation
Sep 15, 2010 10:34 PM
corsair_105
13
Feb 25, 2010 09:06 PM
Xavsbud
Nov 9, 2005 05:15 PM
