frustrated
Old May 18, 2007 | 09:29 AM
brknhrtdpimp1489's Avatar
Default RE: frustrated
naw my ecu is under the hood...right behind the fuse box...i wish i did know someone else with a 420a though b/c i havent though about that yet...
Old May 18, 2007 | 09:55 AM
Dookitchen's Avatar
Where do you live BRKN?
Old May 18, 2007 | 10:15 AM
north carolina??
Old May 18, 2007 | 10:20 AM
Dusty Eclipse's Avatar
Are you asking us or telling us? lol
Old May 18, 2007 | 10:25 AM
Dookitchen's Avatar
oh man too far from me...
I was going to over you to test your car with my ECU. I have 420a as well
Old May 18, 2007 | 10:26 AM
no im saying i live in NC but i was wondering why he asked...lol
Old May 18, 2007 | 10:45 AM
lol well thanks for trying atleast lol...dookitchen...i think im just gonna try and sell it...i found a gst for 1200 that needs a little work but nothing i cant handle...
Old May 18, 2007 | 10:51 AM
RCJr9186's Avatar
how have you checked the fuel and the spark? are you posative that you aren't gettin either of them? to check for fuel you could put a lil bit in the intake manifold... for the spark you can try the old screwdriver trick.
Old May 18, 2007 | 10:53 AM
I Drive Naked's Avatar
*For those that don't know the screwdriver trick*
Insert the end of a screwdriver into a plug wire and turn over the engin.
If it sparks... you've obviously got spark.
Man, I don't lead you on and on, but have you checked all your fuses... ALL of them?
Old May 18, 2007 | 10:56 AM
i know im not getting fuel b/c theres a pressure release valve that looks similar to the stem on a bycicle tire on the fuel rail...when you turn the key to the on position the fuel pump is supposed to come on and put fuel into the rail and get the injectors ready to put fuel into the cylinders...well when you press that valve gas is supposed to shoot out but i have none and to check the spark i pulled on of the plugs and make sure it had a ground and turned the engine over...no spark...
ps...when i hard wired the fuel pump to the battery then i had gas in the fuel rail at the pressure release valve...
