frustrated
Old May 18, 2007 | 11:27 PM
  #41
silvercoupe97's Avatar
Default RE: frustrated
Wow, there must have been something going on while I was typing that last post...it's so scattered, lol. Sorry about that.
I'm pretty sure yours is a OBDII, I have 95 wiring and it's OBDII also.
The middle prong doesn't do anything for the car, btw. The Radio Shack relay has been used in a lot of Eclipse/Talons N/As and Avenger/Sebrings for many years, so I can promise you that it's fine
I can help you decifer the MIL code too. It's best if you can get the P code, but we can start with the MIL to help get a better idea of the area, since you're not able to use the scanner.
Is your CEL on at all? If not, you may not even get a MIL code, lol. If you've resently unplugged the battery, it's a good chance that the only code you will get is 1-2 or 12, which is simply...power was removed within the last 50 cycles..no big deal because it's normal to get that after you've removed the battery.
Old May 19, 2007 | 10:00 AM
  #42
brknhrtdpimp1489's Avatar
no cel and yes i removed the battery a few time lol i didnt wanna mess anything up while i was working on it so i just unhooked it just incase...anyways ok so the raido shack relay is fine what about the fuel pump relay if thats bad will that have any affect on the asd relay b/c if it does then i prob need to replace that relay too...
yinglingj
Mar 11, 2014 05:12 PM
nick_200321
Jan 28, 2008 10:02 PM
nick_200321
1st Generation
Sep 23, 2007 03:19 PM
mirageEvo99
Mar 10, 2007 11:42 PM
kornkid1215
Jul 18, 2006 07:50 PM
