frustrated
Old May 18, 2007 | 11:48 AM
  #31
Dusty Eclipse's Avatar
Default RE: frustrated
Hey, LICK the coil packs terminals. Youll KNOW if that works, lol... Sorry, I had to.
Old May 18, 2007 | 11:54 AM
  #32
I Drive Naked's Avatar
this ones cheaper
420a ECU
Old May 18, 2007 | 11:59 AM
  #33
...with no Buy it now and a week or so end date. The part there is also brand new and will prolly end up going higher than 100. But thats up to Brkn.
Old May 18, 2007 | 12:06 PM
  #34
brknhrtdpimp1489's Avatar
RCjr i havent tried the screwdriver trick yet but i'll do it this afternoon...i do have one question though...the faq about the relays says that the fuel pump relay is on the left and the asd is on the right...would that be standing in front of the car looking towards the firewall or from the driver seat looking towards the engine...j/w...and lol funny dusty haha but anyways...i used the new relay and it just didnt do anything...im lost lol...
Old May 18, 2007 | 12:09 PM
  #35
hey joshewuhh that ecu doesnt look the same as mine...wus up with that its says its for a 420a but it looks like it has more prongs than mine does...
Old May 18, 2007 | 12:16 PM
  #36
Slurp slurp... lol... hahahaha... sorry.That ECUlooks like it belongs to your car. Its just painted black... why? I have no idea.
Old May 18, 2007 | 12:20 PM
  #37
lol your so wrong dusty...my part that the plug goes into doesnt look like that...i think it only has three rows of prongs...idk mabe im just remembering wrong lol im not perfect...
Old May 18, 2007 | 03:33 PM
  #38
hey RCjr i did the screw driver thing and it didnt work...def no spark...im so confused...lol...i guess that just leaves me with the ecu and if that doesnt work then idk what to do...
Old May 18, 2007 | 05:09 PM
  #39
silvercoupe97's Avatar
ORIGINAL: brknhrtdpimp1489
i do have one question though...the faq about the relays says that the fuel pump relay is on the left and the asd is on the right...would that be standing in front of the car looking towards the firewall or from the driver seat looking towards the engine..i used the new relay and it just didnt do anything...im lost lol...
That's while facing the motor. The relays go like this...facing the relays from the front of the car...fuel, ASD, (only if you have an auto of course) ATX, ATX reverse.
The ignition system if fairly simple to follow, but to keep from getting headaches (too late, lol). The CPS, CAS, and ASD relay are the "sensing" components (to all sorts of timing issues), then ECU/PCM (obviouse what this does).
I'm suspecting the ECU now too, since you can't read codes.
...but first, do the "keydance". Do you know what that is? 95-97 DCX/Mitsu cars allowed DIY like us to point to an area of fault with MIL codes.
Anyway, turn the key to the "on" position without turning the motor over 3 times with roughly a half a second pause in between each turn. On the 3rd time, stop and keep the key in the "on" position. All the dummy lights should go out like they do. The CEL will flash a number of times. This is the code and they go in pairs....1-1, 2-4, etc. This will help in getting into the area of concern.
Try this and let us know what happens.
What kind of relay(s) did you use for the ASD/Fuel?
Old May 18, 2007 | 11:06 PM
  #40
i used that one from radioshack...it doesnt have the middle prong that the original one had...do you think this might be a problem...anyways i'll try and see if i can get that code but if i can do you or anyone on here know how to decifer it...im definately not getting spark bc i did what RC told me to do but it didnt work notta no spark still no fuel...just nothing...and a buddy of mine told me that all cars 96 and up are OBDII and 95 to like 90somthing are OBDI would that make me not get a code since i have a 95 talon and was using an OBDII scanner??
