fuel pump? fuel filter?
hey there'I've got a '95 Eclipse GS with a 420 alpha engine and trouble with the fuel system right now.
can anyone tell me if the fuel pump is in the tank or not?
and where's the fuel filter located?
thanks bunches!!! I need to have the car running tomorrow
on my 99 GS my fuel filter was on the passenger side of the car just infront of the passenger rear wheel. just follow the fuel line and you'll see it. takes all of about 10-15 mins to fix.
as for the fuel pump. pull ur back seat up. you'll need a 10mm to get 6-8 nuts off to pull the plate up, after that, disconnect the fuel lines and power wires and the pump should come right out. only about a 30-50 min install. btw, i have a walbro 255 available for the 420a if you are intrerested.
not sure about that john. here's the link to the classifieds add that i have for it. - https://mitsubishiforum.com/m_203702.../tm.htm#214865
MNalfa
17
May 9, 2019 06:07 AM
