fuel pump? fuel filter?
Old Mar 18, 2008 | 11:10 PM
Germankat's Avatar
Default fuel pump? fuel filter?
hey there'I've got a '95 Eclipse GS with a 420 alpha engine and trouble with the fuel system right now.
can anyone tell me if the fuel pump is in the tank or not?
and where's the fuel filter located?
thanks bunches!!! I need to have the car running tomorrow
Old Mar 19, 2008 | 06:43 AM
dsm1990gsx's Avatar
Default RE: fuel pump? fuel filter?
The fuel pump should be on top of the tank, you can get to it by removing the rear seats. The fuel filter is in the engine bay.
Old Mar 19, 2008 | 07:00 AM
To be exact the fuel filter should be located on the firewall low sorta near the windshield washer reservior
Old Mar 19, 2008 | 08:12 AM
RCJr9186's Avatar
on my 99 GS my fuel filter was on the passenger side of the car just infront of the passenger rear wheel. just follow the fuel line and you'll see it. takes all of about 10-15 mins to fix.
as for the fuel pump. pull ur back seat up. you'll need a 10mm to get 6-8 nuts off to pull the plate up, after that, disconnect the fuel lines and power wires and the pump should come right out. only about a 30-50 min install. btw, i have a walbro 255 available for the 420a if you are intrerested.
Old Mar 19, 2008 | 08:19 AM
PappiDread6's Avatar
how much?
On my 420A its also located on the passenger side under the car in front of the rear tire
Old Mar 19, 2008 | 08:33 AM
RCJr9186's Avatar
yea i think it's only located in the engine bay on the gst's and gsx's. i'm just trying to get rid of the pump for $50. that's less than half of what you'd pay.
Old Mar 19, 2008 | 08:37 AM
No. Im pretty sure on the 95-96 GS/RS its in the location that i said. And then on the 97-99 its in the other location near the gas tank area
Old Mar 19, 2008 | 10:07 AM
RCJr9186's Avatar
not sure about that john. here's the link to the classifieds add that i have for it. - https://mitsubishiforum.com/m_203702.../tm.htm#214865
Old Mar 19, 2008 | 11:31 AM
Actually your half correct. After researching a bit more ONLY the 1995 has the fuel filter on the fire wall. The 96+ is in front of the rear pass wheel well
Old Mar 19, 2008 | 05:28 PM
tjbiker031's Avatar
look at the second siggy
MNalfa
17
May 9, 2019 06:07 AM
Black widow
Apr 24, 2014 03:29 PM
c.captn
Sep 26, 2013 06:51 PM
tuckGST
Jul 25, 2008 08:25 AM
Germankat
Mar 19, 2008 06:43 AM
